Latest Programs: --- ODIS-E Flash files (Flashdaten) [03.2019] --- Audi Flashdaten (flash disс) [02.07.2019] --- BMW / MINI / ROLLS-ROYCE ETK [06.2019] --- BMW KSD2 Service Information [06.2019] --- Volkswagen Flashdaten (flash disс) [02.07.2019] --- TOYOTA & LEXUS EPC ALL REGIONS [03.2019] --- Mitchell Estimating UltraMate v7.1.236 [06.2019] --- JCB ServiceMaster 4 v1.81.1 [07.2019] FULL --- Renault Re-Prog CD v177 [05.2019] + Re-Prog Guide --- VAS-PC Flash Discs [05.2019] --- VOLVO PROSIS Offline Part & Repair [01.2019] --- Cummins INCAL - ECM Calibrations [06.2019] + (RMI) + (SIR) --- TecDoc CATALOG (Alliance) Q2 [04.2019] FULL --- Toyota Techstream v14.10.028 [04.2019] + ACTIVATION --- Nissan & Infiniti Fast EPC [02.2019] --- Mitsubishi MUT-III PRE 19031-00 Diagnostic Software [2019] --- GT Motive GtEstimate DVD [03.2019] --- Renault CAN CLiP v187 [04.2019] --- MAN Mantis v.606 EPC [03.2019] --- Toyota Industrial Equipment EPC v2.16 [02.2019] ---
Vw
Flash files for VAG ODIS Engineering (E) Volkswagen
[Image: image.jpg]
[Image: 2v96hxy.jpg]
Year / Release Date : 2019
Version : 07.2018
Language : English
Firmware for Volkswagen (flashdaten) on 03/05/2018. Official software updates for vehicle control units. For the convenience of users in the unpacked form - you can download only the necessary firmware.
You can use with VAS-PC and ODIS Engineering.
to work with VAS-PC / ODIS-E, a VAS 505X diagnostic adapter is required. With ODIS-E, you can use the J2534 PassThru interface (Tactrix Open Port 2.0).
There is the possibility of firmware via Vag Can Pro (It uses the same name cable), as well as converting .sgo to ordinary binary files. Through VCDS and the like Vasi-Diagnostics to implement the firmware will not work.
Thanks given by: Condorh , PoppinI , Howardflelt
